I can see my named views and use them, but I am not able to make new views. Can someone help me fix this problem?
Thank you!
Thank you!
Hoi -
Is this specific to a specific file or does it happen in a new file from a factory-default template? Please run the Rhino SystemInfo command and copy-paste the result here.
Hi Wim,
It happens in every file.
Rhino 7 SR27 2023-2-1 (Rhino 7, 7.27.23032.13001, Git hash:master @ 4a0030c0d354560df03764f4f49ecc5d119e5118)
License type: Commercial, build 2023-02-01
License details: Cloud Zoo
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 32Gb)
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 7-21-2022 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 3060 Laptop GPU (NVidia) Memory: 6GB, Driver date: 1-15-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 528.24
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-15-2023
Driver Version: 31.0.15.2824
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.27.23032.13001
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.27.23032.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.27.23032.13001
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.27.23032.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.27.23032.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.27.23032.13001
Hi -
Can you describe the steps that you take when you try to make new named views? Or perhaps a screen recording?
Hi -
Does this behavior change when you open the Named View panel and change the “View Mode” to “List” instead of “Thumbnails”?
Hi Wim,
I just tried it, but it doesnt change.
Hi Wim,
Is there something else I can try?
Thanks
@dankersdevelopment did you in the meantime solve this issue? Can you make a short screen recording of the steps you are taking and the things you are seeing? Pressing the save button should give you a popup that says “Save Viewport As Named View” Is that what you are seeing?
FWIW I can’t spot anything off in your SystemInfo that is suspicious for this behavior.
Hi Gijs,
Yes the problem is solved.
When using my second screen the popup was not visible.
If I place Rhino on my first screen the problem is solved. The developers of Rhino are gonna check why this happens when using two screens.
@dankersdevelopment thanks for reporting back, for now I marked that as a solution for this thread.
