After updating to Win11, Rhino 7 viewport freezes when switching from shaded to wireframe display.
If you switch to shading again, the screen display will return. It will also accept commands. Wireframe doesn’t work.
I tried it with Rhino 6 in the same environment, but it does not cause such symptoms.
Are there other symptoms like this?
what should i do?
Hi @nisiyama-syoichi
Start by runnning the SystemInfo command in Rhino and post the entire resulting text here - that’ll give an idea of what’s going on. Could very easily be a graphics card driver needing an update or similar.
HTH, Jakob
thank you.
Systeminfo looks like this:
Rhino 7 SR29 2023-4-17 (Rhino 7, 7.29.23107.03001, Git hash:master @ 5f05ef3a2eea3d910c4c2fb79ccc75b413d33ca7)
License type: 商用版、ビルド 2023-04-17
License details: Cloud Zoo
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 64Gb)
Primary display: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 2-18-2022 (M-D-Y).
Primary OpenGL: NVIDIA Quadro T1000 (NVidia) Memory: 4GB, Driver date: 11-26-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 527.37
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-26-2022
Driver Version: 31.0.15.2737
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Users\AE1500\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Users\AE1500\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\IntelDenoiser\0.6.4\IntelDenoiser.Windows.rhp “IntelDenoiser.Windows” 0.6.4.0
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\GeoplotPluginCommon (a530d18a-fe14-4056-a82a-d5f69c8239b1)\2.5.1.2\GeoplotPluginCommon\Rhino 7\GeoplotPluginCommon.rhp “GeoplotPluginCommon” 2.5.1.2
C:\Users\AE1500\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\ggRhinoIFC\2.2.40.0\ggRhinoIFC.rhp “ggRhinoIFC” 2.2.40.0
C:\Users\AE1500\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\Bullant\23.2.27.0\bullant.rhp “bullant” 23.2.27.0
C:\Users\AE1500\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.29.23107.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.29.23107.3001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.29.23107.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.29.23107.3001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.29.23107.3001
I suspect you have a conflict with one of your plug-ins.
In Rhino Options > Plug-ins, change the list filter at the top to “Plug-ins that do not ship with Rhino”.
Disable all of them, close and restart Rhino.
Then see if the Wireframe problem goes away.
If it does, enable one of the plug-ins, restart, and check again.
If I’ve guess correctly, you’ll find the problem.
Good luck
It also looks like you may be running a 2nd monitor, but only have enough VRAM for ONE screen.
Another test is to start Windows with no extra monitor connected.
I changed the mode back to default and it worked.
thank you.
The wireframe mode was importing the custom settings in Rhino6, so that’s the cause.
Enable your plug-ins again unless you don’t use them.
Cheers
I was using 2 screens (4k Monitor).
Other members using one screen do not seem to freeze even with the same mode setting.
