I tried resetting everything a few times to make sure I didn’t accidentally fiddle with an advanced key. But I don’t think I did. See e.g. these screenshots from last weeks build for reference (i.e. where the frame/border was still there).
Would it be possible to at least add an option to get the borders back? Failing that, can you point me to the advanced key that sets the color of the borders between viewports (might work better if I could make that the same as the content/frame color)?
Edit: But other than the issues I’ve reported, the Rhino 9 GUI is looking/working most awesome
That would be Rhino.UI.ThemeSettings.Frame.ViewportDivider. And it does indeed help a bit. Still much prefer the thin/crisp/subtle Rhino 7 borders though
I’ll bring the 1px viewport border back as an advanced option if I can make it optional. Note that the change I made removed that pixel but also the extraneous padding on the viewports, which you probably didn’t notice much because of your single color setup for frame and content background.
For the current default colors the viewport borders are worse ( most noticeable in dark mode, especially when using darker viewport backgrounds).
Though the inconsistency with both Grasshoppers is a bit jarring. But I suppose the Rhino 8 GUI design with the frame/content background logic is a break with the preceding designs in general. iI would be nice with a bit more consistency across the board (even if that would be adverse to my preference).
