Missing toolbars in latest BETA (9.0.26223.12303, 2026-08-11)
I just installed the latest BETA and noticed that the top and bottom toolbars are missing. The right side panel for Properties, Layers etc is empty, as well.
I had a nearly stock Rhino BETA up until today (no additional display modes, I just changed disabled the extrusions and made the maximizing of the active window by a single click).
RhinoSettingsForSupport (Missing toolbars).zip (1.4 MB)
When I wanted to reset the program, I also noticed that the vertical list with commands is smaller than the usual size. Note that I use 200% scaling from Windows 10. However, I have never had such an issue in the past.
After I reset the program, the toolbars remain hidden…
YT here - RH-97739 All settings wiped on newest Beta
Looking into this.
When I tried to import my old settings from one month ago, the toolbars remain hidden.
Bobi,
Try going into Window Layouts and select the default layout - this brought toolbar and sidebar items back for me.
Obviously if you have a saved layout you can select that instead of default.
HTH
Jeremy
I did that and it seemed fine for a moment (the up and down arrows of the Command line history were still missing). However, after I closed the program and started it, the toolbars were gone again.
Rhino 9 BETA also no longer uses my macros that I set from my 3d mouse. I made another topic regarding that particular bug.
Bummer! But, for me, they remain in place after a restart. As for the command history, the arrows seem to have been replaced with a blobby scroll bar, but it only appears when there are sufficient lines of history to need it.
The up and down arrows to scroll the command history never show on the latest BETA, despite that I ran multiple commands. It’s just a missing element from my installation, even if I reset the program. There must be some bug that prevents those graphics elements to show up properly. I read that a few other users also reported a similar bug last night.
I have seen this twice, but cannot recreate it. For me it has something to do with running an update.
But only for the next opening, after which they disappear again! See: Today's beta update wiped out everything - #15 by jeremy5
I have PM’d a private build that should bridge until the next release
Seems like the new build is working fine this time around. Thanks for the quick fix!
I find a little inconsistency with the width of the area where the up and down arrows are located on the right side of the Command line and Command history field. The upper one is slightly wider by a few pixels. Was it made this way by design?
Edit: Later I found that when I open the side “Display” tab, the right-side panel will get stuck and refuse to hide again. It will stay open, no matter if I switch the auto-hide function or not. It remains this way even after I restart Rhino.
From what I remember, I only switched to my custom display mode “Bobi X9”, then I opened the “Display” panel and changed the “Curve width usage” from “Use object’s width” to “Pixels”.
Bobi X9.rar (173.0 KB)
Also, the mouse tooltip hides outside of the screen when I put the mouse pointer over the icons on the vertical right side toolbar.
Another bug that I found in this latest build is the inconsistency of the selected objects counter. I created a separate topic about that here:
Again, that spinner shouldn’t be there. You have already reported this and it is on the list
→ RH-97628 CommandPrompt (Eto): Redundant Spinner
I asked a question about the difference in width, because removing the extra pixels off the upper “spinner” to make both columns equal in width would create a nice visual consistency.
By the way, the link you provided shows a completely different style of the upper rounded button (or a slider?), where the command history is located. It’s nearly twice as thin and I suppose that this is due to making a screen capture on a Mac? On Windows 10 I see two arrows instead.
I like the arrows, because they let me shift the Command history precisely by one row at a time. If I try to do the same with my mouse scroll wheel, it shifts the Command history every 3 rows.
I also noticed that the bottom pair of arrows in your example are inside narrower buttons, but the active hovering area (the blue framing) in your example is much wider than mine and expands by several extra pixels to the left side. Do you mention these as redundant? Since the Command line is a single row, there are not used. I see them in Rhino 7, as well.
The bug with the stuck “Properties” panel has resolved by itself today. I just opened the latest BETA and the auto-hide function of the right panel works as expected again.
Also, the cursor tooltips no longer hide outside the screen. However, it’s strange that they have a different look now. They were rounded 15 hours ago, now they are rectangular with a darker frame. They also lack the mouse icon inside. I haven’t made any change to the program since last night.
The screen capture in that YT is from Windows 11 without any UI customizations.
Same here, and after importing the standard toolbar I was unable to slide it in it’s position. Display is Direct 3D.
Here is my SystemInfo :slight_smile:
Rhino 9 SR0 2026-8-11 (Rhino 9 BETA, 9.0.26223.12303, Git hash:master @ 535bf21f011dc805eafa540606c59272f4f15b11)
License type: Not For Resale Lab, build 2026-08-11
License details: Cloud Zoo
Expires on: 2026-09-25
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 16GB)
.NET 10.0.2
Hybrid graphics configuration using DirectX
Primary display: NVIDIA GeForce MX450 (NVidia) Memory: 2GB, Driver date: 6-3-2026 (M-D-Y).
Integrated accelerated graphics device (shares primary device ports)
  • Laptop’s primary display device
Secondary graphics devices.
Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 6-9-2022 (M-D-Y).
Integrated graphics device with 4 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
  • Secondary monitor attached to adapter port #1
DirectX Settings
Safe mode: Off
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY SkylakeX MAX_THREADS=64.
C:\Program Files\Common Files\McNeel\Rhinoceros\9.0\Plug-ins\Bella (813de3fb-18eb-405f-bfcd-b0b4d3da91fb)\24.6.0.0\bella_rhino.rhp “Bella” 24.6.0.0
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.26223.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9 WIP\Plug-ins\3dxRhino.9.rhp “3DxRhino.9”
C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.0.26223.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.26223.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.26223.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.26223.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.26223.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp “SectionTools”
RH-97779 is fixed in Rhino BETA
