How can I view lines, curves and edges with colour settings set from the custom swatch in rendered mode?
Even though I’ve set surface edges to true in Rhino display settings for rendered mode, they don’t show up when using custom swatches in Grasshopper. They only show as default Grasshopper red.
I mostly use PreviewLW (Custom Preview Lineweights) from Human to make this work. I’ve used it in Rendered, Artic, and Raytraced mode before, and works like a charm.
Otherwise, you’d have to tweak your display settings in the Rhino settings - I guess -, which wouldn’t really be parametrically controllable, unless you come up with some kind of script to do it from Grasshopper.
Mesh edges can be turned off in Grasshopper under Display > Preview Mesh Edges.
Isoparms and brep edges need to be turned off in the Rhino preferences.
I tried turning them off in the rhino preferences. It does not affect grasshopper geometry. They seem to use different settings to control isoparm visibility
