View Capture to File cannot change resolution
When I try to use “viewcapturetofile” command to save a screenshot, the options buttons is disabled and I cannot change the setting to make the resolution higher. It prompts to save the view with some default settings. Does anyone know how can I capture the view in higher res? See the disabled Options button below
The User Interface on this command is not good. We’re working to fix it. For the moment, use the dashed version of the command -ViewCaptureToFile and you will be prompted to set the resolution of the image after you have selected where you want to save the file. Not logical, I know.
-Dan
