i want to save my viewport as 4k image… is there any way to do that? capture to file does’nt seem to have options for changing the resolution
Use -ViewCaptureToFile [i.e. with the “-”] to show options on the command line.
yeah its worked tnx
In Rhino 6 ViewCaptureToFile will pop up a dialog where you can change the resolution. The dashed version works like @wim says.
