Vibration\wavy lines
I was wondering if there is any component that make “vibrating-wavying” a straight line.
I saw this pattern and I was wondering how to recreate it:
pattern.pdf (3.2 KB)
thanks
your question is not very precise and your pdf not very useful. As it is a parametric question, what are the parameters you want, wave length, amplitude, for straigth line, curves … For what end ? To apply it on a surface and then solidify …
It is also good to give credit, image source …
For 3d volume the closest I know is here, Sverchock (Blender plugin ?) done/used by @alessandro.zomparell
I want just transform a straight line into a wavy one. Like I did in the pdf (by hands). One important parameters is the amplitude and the frequency of the wavying.
This is my script, if I have a straight line is working. If I have a curved line I can’t manage to create the weave perpendicular to the curve itself (it is always moving on the y axis)20181105_wave pattern.gh (12.1 KB)
I hope is more clear now
Have a look at the attachment.
20181105_wave pattern_re.gh (15.4 KB)
Here is another way of doing, you have wavelength, amplitude and angle of rotation around the curve
Slightly modified and use of Dendro plugin to solidify an helix
20181105_wave pattern_LD.gh (37.9 KB)
Laurent,
You’re creativity toward solutions never ceases to inspire.
Cool idea.
