I have installed ver 6 trial twice to fix a toolbar not showing, I have also run the toolbar reset as instructed, I have contacted support three times but not getting anywhere fast , after 5 days of trying I cannot find anywhere in the product where I can edit the Dimension properties, like height of text, position between dimension lines etc in ver 4 there was a properties you could edit, I cant find it in ver 6,also any dimension I create on some imported drawings does not contain any text at all, and on others they do, and the dimension lines have no arrows etc and as I zoom in and out the lines detach from the part, the tool bar after the second install showed all the dimension sub options across the bar but as soon as I opened an existing drawing that was imported, the sub options disappear and I am now left with just the linear dimension icon with the expand triangle in the corner, I am a novice user trying hard to come to grips with this version and any help would be much appreciated.
Hello -
Please run the SystemInfo
command in Rhino and copy/paste the results here.
Rhino 6 SR23 2020-2-24 (Rhino 6, 6.23.20055.13111, Git hash:master @ 8106edaa648ba209a8fc587f0f7fcccbaac09169)
License type: Evaluation, build 2020-02-24
License details: Cloud Zoo. In use by: Graeme stebbing ()
Expires on: 2020-06-06
Windows 10.0 SR0.0 or greater (Physical RAM: 7.9Gb)
Machine name: GRAEME-ELITE
Non-hybrid graphics.
Primary display and OpenGL: Intel® HD Graphics 3000 (Intel) Memory: 2GB, Driver date: 5-19-2016 (M-D-Y). OpenGL Ver: 1.1.0
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Microsoft Corporation
Render version: 0.0
Shading Language: Not supported
Driver Date: 5-19-2016
Driver Version: 9.17.10.4459
Maximum Texture size: 1024 x 1024
Z-Buffer depth: 32 bits
Total Video Memory: 2076 MB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.23.20055.13111
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.23.20055.13111
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.23.20055.13111
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.23.20055.13111
Thanks - I’d start by updating the video drivers on this machine -
Open the Notifications panel (Panel menu) and look for a notification about drivers - double-click on that and follow along to get to a newer driver - download and install that and see how things work.
