I’m on Rhino 6.29.20238.11501 and the new VisualARQ 2.9.1.14486
I’m fairly new to VisualARQ but am liking it a lot so far.
I’m modeling a building with a lot a curved and unually shaed walls which makes me use the WallFromCurves and the vaWallFromSolid a lot.
I’ve observed that a vaWallFromSolid does not seem to take on the wall style I assign to it. I’m using a wall style with 2 layers. The regular wall and WallFromCurves shows the wall ok but the FromSolid remains to be a white block in perspective view and does not show any hatchings in other views.
I thoroughly looked around in the forum for someone who has posted a similar issue but I didn’t find anything.
Does it make sense that this does not work? I can assume it does because a “solid object” can have any width so how would the style know which portion in thickness of what style would have to be applied to the total width. Does this make sense or am I doing it wrong?
If this is normal behavior, what do you suggest to work with multi-layer walls in case of highly irregular buildings?
Thanks in advanve for your help,
Walter
