I set a solid to VisualARQ Wall object and set the same style to the wall, but in perspective view and plan view, the normal wall object can show the section hatch correctly, but the wall which I defined from solid didn’t show the hatch. Any idea about this issue?
Hi @h30190, I guess the “normal” wall has the section attributes assigned to the wall layer directly, while the wall created from a solid doesn’t follow the features of the wall style layers it gets assigned (such as the number of them, the thicknesses, or their attributes.)
So you should set the attributes of the wall layer “By Parent”, and assign the section attributes to the style directly.
Or you could also set the attributes of the entire style “By Parent” and assign them to the object directly.
