VaTags - What determines gap between text and outer edge of tag
In VaTags, what determines the overall size of the tag when using a custom block? More specifically, what determines the space between the text and edge of the border? Is that space controlled by the annotation style?
In the image below you can see where I have two different door styles (the right pulling just the element, and the left pulling the element and door size). Both tags use the same custom block, but the tag in the left one is massively bigger with a much larger space between the text and the border. What determines that space?
What I would like is for that space between text and tag border to be much smaller so that the tag can be much tighter to the text and take up less room on paper.
Hi @Martin_Hodges tags created from blocks adjust and scale their size according to the text size and length. But it is not possible to control that margin. We may add an option to have more control on this parameter in future versions.
Hi @fsalla,
I agree that block-based tags have their limitations, but I’ve noticed another inconsistency.
I understand that VisualARQ automatically resizes the block geometry to fit the text, but why isn’t this scaling consistent between Horizontal and Aligned orientations?
Using the same block, tag style, text, and annotation settings, I get different symbol sizes depending on the orientation. In particular, a tag aligned with a vertical opening becomes noticeably smaller than the same tag displayed horizontally.
Even if automatic resizing is intentional, I would expect the resulting symbol size to remain consistent regardless of orientation.
Ideally, I’d also prefer an option to preserve the original block dimensions, independently of the text length.
Hi @badileanu the behavior of tag from blocks is not consistent when not using the Uniform scaling option, and also it doesn’t work well with the “Aligned” orientation, when the Uniform scaling is checked. This will be revised in future VisualARQ versions/updates.
