Size of tags and tables - visualarq
Greetings,
I try to adjust the sizes of the tables and tags to the scale I work at, we work in centimeter and we can not adjust the sizes, I would be happy for your help on the subject.
Hi @11170 the size of the text in tables or tags is determined by the dimension style assigned to the table and tag style. This can be changed in the corresponding styles dialogs (vaTableStyles and vaTagStyles), from the Attributes tab:
By default, the dimension style is set to the current dimension style in Rhino. But you can change it or also edit the Text style to change the text size, which will override the text size set by the Rhino dimension style.
