VARQ3- Rhino 8
For some reason Tibidabo plugin for VARQ causes crashes while opening Grasshopper from Rhino. I disable it, restarted Rhino and problem solved. I went VARQ and downloaded latest version(last week) but problem persists.
File.3dm (6.9 MB)
I tried to open a new Rhino file and tibidabo didnt crash rhino.
Any hints?
Hi @M-user which Grasshopper add-ons do you have installed? Can you try to disable the third-party add-ons and see if the problem persists, when VisualARQ is loaded?
First of all, try to disable GH (and keep VisualARQ loaded), and see if the crash persists.
Disabling GH and keeping VARQ loaded doesn’t lead to any crashes.
It’s strange that the bug is no longer persisting, even though the settings are the same. Last week, I conducted a deeper test with the add-ons, and only disabling Tibidabo prevented the crashes.
Anyway, in case the bug appears again, I will keep in touch.
Hi @M-user there must be some Grasshopper add-on that is interfering with VisualARQ and causes the crash. If you want to figure it out which one is it, you can disable them one by one and repeat the test, until the crash occurs again.
Let me know if you find out which add-on is causing the issue, as I’m interested in reproducing this error to see if we can do something to prevent it.
