My goal is to create a variable bridge cross section following two lines (edges of the road).
I’ve done this by creating points along each line, and then creating construct planes aligning to each point from which I ‘ofset’ the other points for the cross section.
This has worked well, except that for unknown reason, some of the construct planes (first and last part) are rotated 90 to 180 degree relative to the others, making the cross section at those points either lying flat or upside down.
Does anybody know what the cause of this could be, or if there is a better way to achieve the desired result?
Let me know if you need any more information, .gh and .3dm files of the script are attached.
Thank you
//Rasmus
Beam_2line.gh (25.3 KB)
Beam_2line.3dm (132.7 KB)
