If Va project has been open and saved in an instance of RHino in which Va is deactivated, can the Va elements be stable and reworked if then opened again with Va active? Are there circumstance which can either enhance or inhibit this?
Hi @djhg, you can open a .3dm file that contains VisualARQ objects with a Rhino that doesn’t have VisualARQ, and as long as you don’t explode the VisualARQ objects (that will be read as “block instances”), you can save the file, open it again with a Rhino that has VisualARQ loaded, and VisualARQ objects will be fully funcional, with all their parametric features and parameters.
