VA3 - How to remove Level Bottom offset
Hi @fsalla @enric
in VA2 there was the possibility to determine the bottom offset of a Level. In VA3 this seems to have been removed. Ok, nothing wrong with that, BUT why there seems to be hard coded -50mm Bottom offset that I cannot remove?
Hi @Toni_Osterlund I guess the column where you can edit the Bottom offset value is hidden or too narrow. Try to expand it by grabbing the line between columns.
level manager columns
