Elevation height issue
Hi. I am testing VA3 recently and I encountered an annoying issue. I have used the height constarined button.
Consider I have two wall at level 1 and 2 respectively. For example i am changing the level of the bottom wall te wall height increases but the upper floors level are not changing or decreasing.
Hi @asisintel, changing a level’s height will affect the elevation of the upper levels, but not their heights. If you want the objects located on the upper levels to update their location, you will need to activate the constraints button next to each level.
On the other hand, if you don’t want the upper levels to be affected by a change on the lower level, you can just edit the elevation of the level above the one you want to edit.
Does that all make sense to you?
Yes that make sense. Thank you
