Hey Guys,
I’m noticing that the offset option for slabs isn’t enabled. This would be handy for showing a finished floor and keeping subfloor alignment to a level guide. Is there a way to accomplish this?
Thanks!
-Clay
Hey Guys,
Thanks!
-Clay
Hi Clayton,
I guess you are asking for a slab offset in the elevation direction, right? (we have other requests for adding a slab offset to expand its boundary). In any case, we haven’t implemented this feature, so I add your vote for it.
The workaround I can think of right now is to have a slab style with a top layer that you can hide (either by Layer, or by setting the visibility of the component to Hidden (in the styles dialog > attributes > Visibility). Then, from the slab properties panel, you can edit the thickness of that layer, so it would act as the slab top offset.
