In VA2, when I drag the arrows at the end of a wall, beam, etc they would snap to a nearby reference object.
Do these arrows still allow OSnap in VA3? I can’t seem to get them to snap to nearby objects.
thanks
thanks
Hi Thomas,
How are you reproducing this problem? I still can snap to objects:
Alfonso,
I’m actually referring to the little arrow symbols. Here are some comparisons between VA2 and VA3. Maybe it is some setting they changed in Rhino 8 about how things snap? not sure.
I have the same issue.
I is what i tried mentioning it here VA3 wall extend bug - #2 by alfmelbev
It only appears in the current version of VA3. In previous releases, the problem doesn’t exist.
Too bad, I saved my model in the current version ![]()
Hi @arcus, @rbialozor we will try to fix this for one fo the next Beta versions, or at least for the final release. I’ll keep you posted.
Hi @arcus @rbialozor I’m glad to inform we have just published the new VA3 Beta 5 version that fixes the issue of control arrows not snapping correctly: New VisualARQ 3 Beta 5 released! - #6 by enric
Cheers!
