I have multi layered walls in my project that are made with VisualARQ’s wall tool. I wonder if it possible to make only the wall’s outlines wider in section views and not the other layers? I have tried to adjust line widths using VA wall’s section line print width and separate wall layer’s print widths. I have only managed to make all section lines thin or thick. Hopefully the picture below clarifies my question.
Hi @tuomas.ranta-aho,
Unfortunately it is not possible right now to define a line-weight for the contour of a multilayer wall. We have plans to implement this feature in future versions. So I’ll keep you posted.
Thanks for the quick answer. Would be great to get the feature in the future since this is the standardized way of presenting architectural drawings here in Finland.
Hello, any new information regarding “line-weight for the contour of a multilayer wall” (and also line-weight for the contour of all elements when displayed in section) functionality? It is one of the most basic standards also here in Slovakia.
@Michal_Križo@david25 I still can’t say when we will be able to implement this feature. I understand it is an important feature for producing architectural drawings. I’ll keep you posted.
