I have some poly surfaces as terrains and the plan view show (only in some case!) some single border of every single surface…
Hi @lopez,
VisualARQ section will only show the section pattern if the sectioned object is solid (for example a closed polysurface, capped extrusion, closed mesh, etc).
If your objects are closed, then there is a bug. Please, send us the model to visualarq@asuni.com so we can take a look.
Thanks,
Enric
