I like to scale VA doors and windows in 1,2d But the openings can only be scaled in 3D so it’s a Bug?
Hello @user992,
Which VisualARQ and Rhino versions are you using? It looks like it is working fine with the last VisualARQ version released (https://www.visualarq.com/download/update/). In the following days we will publish VisualARQ 2.12, where it is working fine as well.
2.11.3 version it only scale in 3D I can’t scale width only or height only!!
Hi @user992,
Currently, only openings that use a rectangular profile, or a profile from a curve, can be scaled in 1D. The reason is that the other profile, once scaled in 1D, is no longer valid. For example, a circular profile stretched vertically is no longer a circle.
I’ve added an entry in our bug tracker to fix this issue in a future VisualARQ version.
Thanks,
Enric
Thnaks Enrci
I would mention that the window style wizard is so ugly
, I hope to change it in a future releases
Well, this wizard was created 20 years ago. It wasn’t that ugly then…
For VisualARQ 3 we plan to update our UI. Wizards are probably the first dialogs that we need to modernize. Suggestions are welcome.
Thanks!
Enric
Hi @user992,
I just want to let you know that we have just released VisualARQ 2.13, which fixes this error you reported.
You have all the information about this new version here: VisualARQ 2 - Version 2.13 released
Enjoy!
