There is a problem scaling
HI
When we want to scale a target in visual arq, it only applies to walls, for example we want to compare it to 1/200, it’s just the length and width of the wall.
@RamonC @fsalla :crossed_fingers::crossed_fingers::crossed_fingers:
Hi @mehran09197306634me, when you scale walls or openings with VisualARQ, only the dimensions defined by object are scaled, such as the wall height or length, or the opening widh and height.
In case of the openings, the scaling is not affected if they have already a predefined size. So you need to assign the profile size to “Other” if you want to scale it with the Rhino Scale tools.
Hi
thanks
Yes, I know, but it’s time consuming
About this, if we’d be able to use Scale1D to adjust width and height of windows independently would be excellent, the whole adjust width → re-position would be much smoother.
