V9 WIP bug - Clipping plane issue selecting points with double click
Hi, I’m using WIP (9.0.26021.12305, 2026-01-21)
I’m experimenting an inconsistency with row selection of control points using double click.
V8 works as expected.
Anyone else with the same problem?
Hi Joaquín -
Could you describe the inconsistency? I’m not immediately seeing anything wrong in a quick test.
Hi @wim after doing some tests I discovered that the problem is not the surface itself, but something related to the clipping plane. If you delete the clipping plane the points selection works as expected. The problem is that clipping plane treats visible points as hidden if you change the objects clipped mode from “all” to “selected objects” and no object is selected.
Selection_Issue_260128.3dm (3.8 MB)
Hi @wim and all, I edited my original post and would like someone to take a look.
Thanks
Hi Joaquín -
Thanks, I’ve put this on the list as RH-92108 Selection: Excluded from Clipping Selection Issue
RH-92108 is fixed in Rhino WIP
