Bug: Obscured Control Points Not Selectable
Version 6 SR15
(6.15.19148.13161, 5/28/2019)
Hello - I do not see that behavior here so far. There must be some other setting…
What other setting could it be? It’s the same behaviour under different display modes, window and crossing selections, selection filters enabled and disabled, etc. The only change I’ve made was updating to the new service release candidate earlier this week. What was changed regarding control point selection?
Hello - - do I understand correctly that if you open a new file, make a vertical line in Perspective, turn on its points, and Window select in Top, only one point is selected?
nvm @pascal. Please delete this. I’ve been working on old models that had clipping planes on hidden, locked layers. They were flipped the wrong way…not sure how that happened.
