Please have a look at this.
Sorted few days ago, came back again with the latest release.
same script:
V7
V8 1. Area properties could not be solved on Box.
The bug must be located here:
V7
V8
Hope this helps.
same script:
V7
V7
Hope this helps.
Without being able to examine the geometry, the images alone you posted are useless. If there was a different thread earlier, a link to it might help?
I’m sure you’ve seen this page before, yet you ignore the advice
3. Attach minimal versions of all the relevant files
What do you want me to attach? The Domain Box and area components?
aarea calculation problem.gh (4.1 KB)
Here you go.
Probably these new/hidden settings:
Geez guys.
Read the thread first:
Ja ja I keep forgetting that when you ask Rhino to check for updates it doesn’t actually do it. Wish this page would report update status properly and perform a check when it opens.
Anyway. Flat shading on your capsules?
https://www.food4rhino.com/en/app/capsule-renderer
Great plugin.
Weird I’ve never seemed to get it working on V8. Thought maybe you were using something else. Doesn’t want to activate the plugin.
It works slightly different than V7 but it works, in general.
Maybe some other V8 user can have insight on this problem.
Cough, cough:
Hi Piotr -
Thanks.
→ RH-86038 Grasshopper: Flat Box - No Area
RH-86038 is fixed in Rhino 8 Service Release 17
