V8 Bug: Cut text in text editor doesn't cut the text
I’ve just installed the current version of V8. It’s taken all of 3 minutes to come across a bug: Double-click text (that was created in V8). Select a portion of the text, right click > Cut.
It doesn’t Cut. The text stays selected and stays visible.
If I move the cursor to some point where I want to insert the text, right-click > Paste, it inserts a blank space of about the length of the text that I’ve just tried to Cut…
I noticed the same thing. Is this going to be solved?
This is on the list as:
RH-77626 Pasted text in Text dialog is invisible
I’ve added this thread.
RH-77626 is fixed in Rhino 8 Service Release 17
