In the video below, I Ctrl+C a text from the Object Properties panel to a new text object, and when Ctrl+V it become invisible…
known issue… still not resolved
becomes annoying when there’s lots of short text to be orgaized
It would be nice if it were solved.
RH-80013 Text disappears when copy-pasting in the Edit Text window
Not seeing this in the latest. Going to send you link if you can give it a try. Thanks.
I’m on Rhino 8 SR11 2024-8-20 (Rhino 8, 8.11.24233.01001) and the problem is still visible.
Same here using (8.12.24239.2001, 2024-08-26).
Thanks all. Let’s post SystemInfo and see if there is any pattern in the environments.
My SystemInfo
Rhino 8 SR12 2024-8-26 (Rhino 8, 8.12.24239.02001, Git hash:master @ dbbb8e6010c59773b94c130ed249f0f34b715839)
License type: Commercial, build 2024-08-26
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Primary display and OpenGL: NVIDIA GeForce RTX 3070 Ti Laptop GPU (NVidia) Memory: 8GB, Driver date: 3-12-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.86
Primary OpenGL: NVIDIA GeForce RTX 3070 Ti Laptop GPU (NVidia) Memory: 8GB, Driver date: 3-12-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.86
Secondary graphics devices.
Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 8-7-2023 (M-D-Y).
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-12-2024
Driver Version: 31.0.15.5186
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Users\japhy\Downloads\build\rh8\test-getint.rhp “test-getint” 0.0.0.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.12.24239.2001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.12.24239.2001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.12.24239.2001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.12.24239.2001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.12.24239.2001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.12.24239.2001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.12.24239.2001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.12.24239.2001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.12.24239.2001
Japhy, paste adfasdf in a new line below zzzzz.
Before:
zzzzz
After:
zzzzz
adfasdf
adfasdf is not visible.
Ok, so sometimes it shows and sometimes it doesn’t. I couldn’t find the pattern yet
(Pasting in an existing line = no problem)
Found out something:
When I paste the word “Invisible”, and select it then (while it is not visible), then hit Ctrl+Space, it becomes visible.
Ctrl+Space for removing the text formatting, like in Word etc.
Still haven’t seen it yet.
My Keyboard goes to a windows command from PowerToys with Cntl+Space. I’ll start poking at text formatting/keyboard possibilities.
I could reproduce the Ctrl-Space ![]()
Not me ![]()
Paste:
The
Invisible
Man
Select all, and then try Ctrl+Space - no luck.
In the YT it reads the cause could be an ETO control.
Now I tried in V7, which is not etoish, and the same invisibility happens.
EDIT:
In V7 pasted text becomes invisible only when COPIED from the V8 textbox.
Seems pasting is not the problem but copying.
V5 + V6 behave correct.
The good thing is that they don’t have to wait for a fix in the ETO framework ![]()
Using InsideClipboard from NirSoft, I found out why the text is invisible.
To retrace:
In Rhino V7, call _Text.
Enter a sole q.
Select the q.
Ctrl+C
In InsideClipboard look at the Format Name Rich Text Format.
In the pane below, read the RTF string.
Near the end is a \cf0.
\cf is the control word for the fore color.
Do the same in Rhino V8.
In the RTF string the fore color is missing.
Once the forecolor of the text is defined, copy+paste in the dialog works fine.
Copy this:
And paste below
Thanks Charles, I started a youtrack based on that information. RH-83522
