In V6, the Distribute tool added a great option to be able to control the spacing between objects with “Gap Distance”. I’d like to control the distance between objects on a curve (or srf) instead of calculating the appropriate distance from center to center.
Could we have a Distribute Along Curve? That way, objects on a curve could vary in size but keep the same distance between them.
Could you also add Gap Distance spacing to Array Along Curve and Array Along Curve on Surface?
Distribute is a great V6 addition. Expanding its functionality would really help when placing objects that have to maintain a certain distance from edge to edge. It’s my dream tool.
I think “Distribute Along Curve on Surface” would be my dream version of this tool. Being able to keep the objects aligned with a surface’s normal direction while controlling the space between objects would be ideal.
Hi Mike - seems like that may get a bit tricky for gaps - just off the top of my head - I don’t know how Jarek does it - but in a linear distribution, finding spaces between bounding box edges or centers is straightforward since they are all parallel, but on an arbitrary wiggly curve, are the bounding boxes aligned to the curve normals? If so where do you measure the gap? The closest points on a bounding box might or might not be very useful since adjacent ones will not be parallel. If you do not use bounding boxes, then it gets complicated too. etc.
Hi Pascal, yes, the spacing on irregular curves and shapes is tricky. I use oriented bounding boxes and also two methods of measuring: curve length or equidistant. It would be possible to do it very precisely independent on curve or distributed objects shapes, and with precision, but that would need some sort of iterative approach of “sliding” each next object from the previous object position and checking spacing at each step. Tricky, definitely
I see how the calculating the space between can get complicated. I’m sure this is also why the spacing breaks down even in Armadillo when you offset the objects above or below the curve.
Maybe this is a different way around the same problem I’m having. Would it be possible to add a base surface to FlowAlongCrv for orientation? Maybe it would be Flow Along Curve on Surface. I know that Armadillo can do this well, but I’d love to see it in native Rhino.
There are times when creating a base surface for FlowAlongSrf is insufficient, especially when the target surface has compound curvature. Here’s a simple example:
If I want to place a circle of gems (or whatever) on top of this surface I can use FlowOnCrv using the isocurve as a target, but the gems won’t be normal to the surface.
I could use FlowOnSrf, but I get very different results with different base surfaces:
UV Curves gets me a base surface that’s too long. the distances between objects will be very different on the base and target surfaces.
UnrollSrf fails because the surface is doubly curved.
Smash gets me a surface that is very close in dimension, but it’s not straight so I can’t lay out my gemstones with regular spacing on it. Hence, my original request for Distribute Along Curve.
If I can use Flow Along Curve and still make my objects align with the normals of some target surface, then I could fine tune the spacing between the flowed objects using the current Distribute command on the parent objects on the base curve.
Hi Mike - I believe in the example you give FlowAlongSrf ought to do it, but you may need a rebuilt target surface to even out the spacing - is that what goes wrong? If so, Rebuild (DeleteInput=No) the target surface to a very dense point count like 16 by 64 (around) and use that, then delete it.
Although, in a test just now, it worked out perfectly on the basic revolved surface - maybe I need to re-read your post.
In your example, make a PlanarSrf from the UV curves and use that as the base surface…
Hi Pascal,
This is the exact problem that got me diving into this. Rebuilding makes little to no difference.
Here is what FlowAlongSrf does in this situation.
Both surfaces have been rebuilt to 64U and 16V. On the base surface I’ve got 20 gems with a gap of 0.20 mm between them. On the target surface, i’ve got 20 gems crashing together. Flow Tests.3dm (2.9 MB)
As far as i can figure it out, it’s because UV curves gives me a rectangle that is approximately as long as the outer circumference of the surface. This is considerably longer than the curve that I want to flow onto.
I get closer with FlowAlongCrv, but again, I have to match the surface normals somehow. In this example, it’s pretty simple, but often I’m doing this on a more complex surface and there’s not one angle that works for all of the surface normals.
I’ve gotten further with ArrayAlongCrvOnSrf which is what made me think of adding a target base surface for FlowOnCrv.
Actually, yes. That does make the spacing better.
I had never considered changing my base surface from the frame that UV Curves makes. I’m going to have to try this workflow out in some of my other projects to see if it works consistently.
Hi Mike - another thing to try here is ArrayCrvOnSrf - it is not the easiest to use, OK, it is hard to use, but it may actually do what you want as well. You need to use the Multiple option (20) and specify the diameter of the object plus spacing (1.5 in this case)
I’ve worked with this one a bit too. On occasion it does a fantastic job. Unfortunately, I often need to array tapering gemstones and ArrayCrvOnSrf can’t handle that.
Ideally I’d like to have one very reliable, Rhino-only workflow for laying out different gem settings on convoluted surfaces. My biggest frustration with FlowAlongSrf was that it messes up the spacing so much, but now I’m thinking that there may be a better way to set up my base surfaces.
Hi Mike, I see the issue and have run into this many times on different types of surfaces as well. Good conversation as you need to show those students the right way. I assume GIA is not using Matrix any longer and you guys are using Rhino only. Different ballgame in some instances. In that simple example I would roll out polar array and call it a day.
Agree 100% - Rhino needs a robust editable ‘Array object on curve aligned to surface normal’ tool. Given that the vast majority of jewellery cad designers are using Rhino (or a ‘plugin’, Matrix, Rhinogold, etc) - this is sorely missing. I can get by using ArrayCrvPlus, however Matrix has had a fully-functional, editable solution for years now. As a die-hard vanilla Rhino user, that’s the biggest hole I can see for users like me, and is the single biggest thing missing in Rhino at the moment for the jewellery industry.
Stuller/Gemvision/Matrix is developing all these new features like Live Booleans (which are now becoming commonplace in 3d software) - McNeel needs to step up and make vanilla Rhino a viable option for jewellery cad designers.
