When using the Polyline command, there’s a new behavior to exit the command when compared to previous versions. (not sure if this is intentional or not so, I’m not sure if I’m complaining or pointing out a bug )
• run Polyline
• click a few points to create a polyline
• press Enter
• leave the command as expected
now…
• run Polyline
• type a numerical value because you want a particular distance for the next point.
• mouse click to set that point
• press enter
• you haven’t left the command
you’re still in it and the only way to leave without adding more points is to put your cursor on the last point and press enter/spacebar 3 times (essentially making a duplicate point or zero length segment)
(if you just press enter 3 times with the mouse somewhere else, it will add an extra segment upon exiting)
another way is don’t mouse click for the last point… put the cursor where the last point is wanted then enter three times.
so yeah, it’d be nice if you press enter once and leave the command… (or, if it worked like V6 where it’s two Enters to leave except it doesn’t place the last segment)
