v510: Show Command Help?
v510 Release notes indicate: “The right sidebar now has a pane that displays context sensitive help. You can also display context sensitive help in a floating window by selecting Window > Show Command Help in the application menu.”
I was delighted to see this (especially for the benefit of new users) and I see the “?” in the right sidebar, but don’t see any content regardless of commands issued. Same if I select Menu > Window > Show Command Help.
Is this another OSX 10.7.5. problem (which I’m running) or am I missing something? Does this work as expected (like in Windows Rhino) for others in later OSX systems?
~Dave
Interesting… It’s now working! Not sure if this took some time to initially load, or what the issue was. After about .5 hours of use, I noticed that it was working. Not sure exactly when it started.
This is truly wonderful. Many, many thanks RMA!!! I imagine this will be a huge benefit for new users.
~Dave
