Hi!
Thinking to move to V-ray 3 for Rhino and now testing trial.
How to turn off ground plane dome hdr reflections? I still want my model to have environment reflections.
I tried google and forum search but I did not find solutions.
I wish you to take screenshots of settings to get to the result.
Your problem is that you’re using a dome light with a map. The reflection exclusions only ignore the Environment channels, not physical light channels.
Remove your dome light and apply your sky hdr to the v-ray options - Environment - Background.
Hi Travis!
Nice to hear and learn why it did not work. Thank you very much!
I feel Vray has great “customer support”! I really appreciate your help!
If we will see some day, I’ll order a beer for you
One more thing about this. How to get environment invisible from the background? I tried to change setting in environment but did not get results… Pictures you sent, there is sky background visible…
When I used dome with hdr there was setting “invisible”…
it sounds like you’re better off taking the object that you want to have sky reflections (cube) and add your sky to that materials background vs trying to have everything in the scene ignore the background accept 1 object.
Might be that you are correct. But in real life there is a lot of parts in assembly… Then I have to make it to all (15 pcs) materials. But in any way, thank you for your great support!
A very simplistic approach is to just save the render as a PNG and the environment background will be transparent. You can then composite onto any background you’d like.
