Hello folks, I’m having some issues that I can’t seem to figure out with my renders, as you can see in this photo below, I cannot turn off the light reflection in the background, but at the same time, I still want to keep the reflection on the ring itself.
wouldn’t it be better to turn the ring only and not the lighting?
As far as I know there is (still) no exclude objects option in Vray for Rhino like there has been (for ages) in 3dsmax.
However, if you make the reflection for the ring with a HDRI environment, rather than a physical Vray light, you could override the environment for the groundplane.
