Rendering Cycles
How do I render without the environment reflecting on the ground plane
Not sure I fully understand what effect you are after. How have you set up your ground plane - material? or shadows only?
Could you provide an image with some more information about what you effect you are trying to achieve?
If you are trying to have the ground plane reflect objects but not the environment - that’s not possible without turning off environment reflections for all other objects too.
