BEMAD
#1
UV mapping isn’t recognize for sub surface when using cycle.
Is this a known bug?
nathanletwory
(Nathan 'jesterKing' Letwory)
#2
Can you attach a simple 3dm file and a screenshot of what you are seeing? I assume this is with the BETA release 6.0.17348.12501 ?
BEMAD
#4
Here a GPS screen…
normal setting: a polysurface with sub surface material.
becomes under cycle…
BEMAD
#5
UV test polysurface.3dm (15.2 MB)
working on the last build 6.0.17346.6021
nathanletwory
#6
Thank you. I see the problem on my machine too.
nathanletwory
#8
Hi @BEMAD,
A bit of a blast from the past, but there is a work-around of sorts until the problem gets fixed for real.
