UV Edtior: Texture shows up as gray
See wooden_box.3dm:
When running UVEditor, then the wooden texture is displayed as gray:
Shouldn’t I see the texture? Is this a bug?
OS is Win7 X64. GPU:
Hi Felix- in the side panel that opens when editing, set ‘Texture’ to ‘Use material’ - does that do it?
No:
Hi Felix - if you change to Use Texture > UV Grid texture, does anything show up? This is Rendered display mode, correct?
Yes and yes:
OK… hmmm- well, the upshot is I do not know why your texture is not showing - Textures show here in my test so I guess I am missing a detail of what you are doing- if you have a simple 3dm file and share-able image that shows the problem, can you post it?
thanks,
Doesn’t my initial post provide that? What else do you need?
Yep, sorry, missed that. Checking…OK, I see the same problem with this file.
Thinking…
Note that, in a new instance of Rhino 5 64, I simply created a box and assigned a standard wooden texture to it.
As a possible workaround for now, I found that if I assign a different material, it shows, and then reassign the Walnut is also shows - all this inside the texture editing. The texture shows as darkened though, so it is still not right.
The same problem I solved with me last week.
And I worried about 2 days !!!
… Because I read in manual that this is a problem in the
settings of the card …
and I tried various drivers …
We got the idea … and
But how the solution is simple doctor Watson ???
Set the material according to the object’s!!!
Not according to the layers …
it does not work (it works even on your model ())
I’m sorry my English is goole!
I’m Not Lying :smile:
Which renderer is the current renderer?
It is whether the set render on Rhino, Flamingo nTx, or a Penguin
(the other I do not have)
Trust me!
Solution: assign the material according to the object (no layer)
Rhino Render:
Indeed, then it works. Thanks, @Revid!
Thanks - I’ve got this repeated. Logging it as bug http://mcneel.myjetbrains.com/youtrack/issue/RH-29608
