Hello, this might be a relatively easy question, but I could not find the answer. I would like to use snap function while moving object, but not to be snapped as exactly point rather only to catch certain axis (z for instance).
Image 1: Original Position
Image 2: Current Snapping
Image 3: Desired Snapping
For the Z-axis, you can run Move and invoke the Vertical option and then snap to that other point.
For the X- and Y-axis (and any other direction in the same plane), you can use the Shift key to constrain the movement to an axis, and then use the Tab key to lock the direction. Then snap to the other point. Also take a look at the “Point filters” section in the help file.
