Ability to lock movement of objects to 1, or 2 axes
E.g., similar to when you press tab along a line to restrict movement into 1 direction along the locked axis, the ability to restrict movement in 2 set axes.
Video explanation (please watch for clearer explanation)
you have the Planar osnap at the bottom of your screen, then you will can move or model based on the plane where you clicked.
Hi Diego,
Even with Planar on, the same issue occurs. I should have had it on for the video to show.
Regards
Set a construction plane for the plane you wish to work on and then check Project object snap.
