Using Rhino after 90 day trial ends?
Hello, My 90-day trial of ‘Rhino’ has ended but I was wondering if you could still use it to view files/ for learning? I thought you used to be able to open up the program but without the ability to save your work after the 90 days was over?
Many thanks,
Simon
Hi Simon -
As far as I know, that should still work, yes.
If I’m not mistaken, I think the evaluation license needs to be installed locally, not in a cloud zoo account for it to continue to work as a viewer after expiration.
@simon.bailey02
@Helvetosaur is correct.
Add your expired license “Locked” to a single computer. Then it will run indefinitely and do everything except Save/Export and load-plug-ins.
It’s perfect as a viewer for inspecting files.
Cheers
