Using gumball arrows sometimes distorts curve unpredictably
Hello.
Is this just me, or someone experienced same issue, when I however over a control point gumball arrow, it turns black, but when you try drag it, it shoots the control point somewhere outside of the screen, while arrow remains at the same position, continue dragging doesn’t change anything, the curve remains distorted, have to drop and undo.
Unfortunately, I’m unable reproduce it at will.
I’m not sure if I miss the arrow or something, or it’s a bug?
[EDIT]
It seems it doesn’t actually move the control point, but it creates a yellow distorted “ghost” curve, that remains visible even after drop, the original curve remains unchanged with visible control points. The ghost curve disappears when I click on empty space.
I was trying move control point on the left:
The ghost remain visible even after selecting original curve
or selecting a control point
I could click on the ghost curve, it highlighted the same control points of the original curve, yet no control point that would explain that “jump”. After I dragged that ghost curve, it went back to original shape and original curve was moved instead.
I think I found the cause of this: 3DCONNEXION SpaceMouse
If view is in motion and I start dragging an arrow it glitches:
v9.0.26209.18303, 2026-07-28 seems to fixed this issue
I hope devs would port it into v8 as well.
