Last couple versions, when I run the automatic update (as with the new 8.24.25273.15002, 2025-09-30 just now) it re-sets my customized ‘Appearance’ colors settings back to default. Please don’t do that. I have the color settings as I like them, and I do not want them reset every time I update.
Can you please help me reproduce this one? I’m having trouble. Here’s what I tried:
I installed Rhino 8.23.25251.13002, launched it, and started a new modeling window.
In Rhino 8 > Settings > Appearance, I changed all the viewport color values to red (I’m red-green colorblind but I do think this is sufficiently weird for even me to notice the change.)
In Rhino 8 > Settings > General > Update Frequency, I set the frequency to Service Release Candidate and checked for updates. I updated to 8.24 and restarted Rhino.
I’m still “seeing red”.
I’ve stopped short of turning on automatic updates (which you did mention). But I’m wondering if there’s some specific colors you change are getting reset, but not others?
When I updated to **Version 8 (8.24.25273.15002, 2025-09-30)** (as well as the update before this one), this reset the color to the default yellow color.
However I just updated to the newest Version 8 (8.24.25280.13002, 2025-10-07), and this time it preserved my custom color.
Sorry, I know thats not much help. Glad it didn’t do it again this time though! maybe it was just a fluke those few times before.
Thanks for the additional info about Selected objects color. I tried again with roughly the same steps listed above, but this time changing Selected objects to red…but again, I could not reproduce the bug.
Glad to hear it didn’t happen again, but I’m still suspicious. I took a look at the code that governs that control and nothing obvious jumps out at me…but subtly bugs are rarely obvious. My guess is we just haven’t figured out the pattern of reproduction yet.
Regardless, thanks for calling them as you see them,
-Dan
PS: I’ll likely never notice this one myself because, as part of what I work on, I’m constantly resetting my settings.
Very weird. I can’t imagine what is causing this. Frustrating. You are in the Service Release Candidate update cycle, correct? (That should not matter, I’m just wondering why we aren’t hearing more reports of this).
There really is no rhyme or reason to this, is there? Not much is changing in Rhino 8’s codebase lately…certainly nothing I can see that explains this.
Hello, I have a similar issue which may relate. I might be missing some save settings or something. But since I started using V8 on Mac, each time the theme auto switches from light to dark mode or vice versa, my custom appearance colours get reset. My layout background resets to gray, my selection colors reset to yellow.
I would gladly appreciate to know the solution to this behavior as it is frankly quite annoying, having to switch it back each time.
Hi @Dan Sadly its worse than ever now. As of the latest update, it just randomly goes back to default. No matter how many times I set my own styles or colors, save it, etc… a day or two later it all jumps back to the default colors. A real bummer.
I have a hunch. Can you check System Settings > Appearance on your Mac and tell me if it’s set to Auto? If so, macOS switches between light and dark mode at sunrise and sunset. Rhino currently resets most Appearance colors (including Selected objects) whenever that switch happens, which would explain why it seems random and why it sometimes lines up with updates. If you set Appearance to Light (or Dark) and leave it there, I’d expect your colors to stick.
I think this is a case of:
RH-86338 Customized colors are reset when switching to dark or light mode
Let me know either way because we need a better solution.
Fore reference, the main one I notice is ‘Selected Objects’ which keeps bounding back to yellow. I prefer a white background, so I set it to a much darker color. But it keeps falling back to the default:
