Update mechanism
Hi guys,
isn’t the update mechanism in the Beta not anymore working? I have to admit it was working from 7.0.20294 to 7.0.20295.18004 in the middle of last week…
Thanks in advance!
Andreas
Rhino 7 SR0 2020-10-21 (Rhino 7 BETA, 7.0.20295.18004, Git hash:master @ 2d4a7a5745d415e03dcb6752fc9743c66211a738)
License type: Commercial, build 2020-10-21
License details: Cloud Zoo
Expires on: 2020-12-05
Apple Intel 64-bit macOS Version 10.15.7 (Build 19H2) (Physical RAM: 16Gb)
Mac Model Identifier: MacBookPro11,3
Language: en-US (MacOS default)
NVIDIA GeForce GT 750M OpenGL Engine (OpenGL ver:4.1 NVIDIA-14.0.32 355.11.11.10.10.143)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 2 GB
Graphics: NVIDIA GeForce GT 750M
Displays: Color LCD (221dpi 2x)
Graphics processors
Intel Iris Pro (1536 MB)
NVIDIA GeForce GT 750M (2 GB)
Color LCD (1440 x 900)
USB devices
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple Inc.: Bluetooth USB Host Controller
Bluetooth devices
Broadcom: Mighty Mouse
Third party kernel extensions
at.obdev.nke.LittleSnitch (5474) 21D3E540-82E5-38B3-9030-999B3D754C89
Third party plugins
/usr/lib/swift/libswiftFoundation.dylib
/Users/andreas/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/bella_rhino.rhp/libbella_dotnet_native.dylib
/Users/andreas/Library/Application Support/McNeel/Rhinoceros/packages/7.0/IntelDenoiser/0.4.1/libtbb.dylib
/Users/andreas/Library/Application Support/McNeel/Rhinoceros/packages/7.0/IntelDenoiser/0.4.1/libtbbmalloc.dylib
/Users/andreas/Library/Application Support/McNeel/Rhinoceros/packages/7.0/IntelDenoiser/0.4.1/libOpenImageDenoise.1.2.0.dylib
/Users/andreas/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/bella_rhino.rhp “Bella” 20.15.0.0
/Users/andreas/Library/Application Support/McNeel/Rhinoceros/packages/7.0/IntelDenoiser/0.4.1/IntelDenoiser.Mac.rhp “IntelDenoiser.Mac” 1.0.0.0
/Applications/RhinoBETA.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.0.20295.1002
/Applications/RhinoBETA.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.0.20295.1002
/Applications/RhinoBETA.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 7.0.20295.1002
/Applications/RhinoBETA.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.0.20295.1002
/Applications/RhinoBETA.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.0.20295.1002
/Applications/RhinoBETA.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.0.20295.1002
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.0.20295.18004
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 7.0.20295.18004
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 7.0.20295.18004
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 7.0.20295.18004
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 7.0.20295.18004
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.0.20295.18004
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 7.0.20295.18004
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 7.0.20295.18004
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 7.0.20295.18004
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 7.0.20295.18004
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 7.0.20295.18004
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 7.0.20295.18004
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 7.0.20295.18004
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 7.0.20295.18004
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.0.20295.18004
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 7.0.20295.18004
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 7.0.20295.18004
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 7.0.20295.18004
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.0.20295.18004
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.0.20295.18004
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.0.20295.18004
Hi Andreas -
There’s a bit of a hick-up in that process at the moment as we are now generating 3 different versions of Rhino 7 for Mac (and 3 for Windows) - 7.0 Beta, 7.0 Commercial, and 7.1.
It sounds like you are running on dailies. That won’t work very well right now. You’ll be told that you are up-to-date on your 7.0 installation and if you check for updates, you will be led to a 7.1 version that is likely older than the version that you are running and that requires a Rhino 7 license…
Until the dust settles, download new public releases from Brian’s announcements here:
Thanks Wim, for the quick clarification!
