Every time I install a V7 update I get an error message saying the install failed. But when I click out of the message and cancel the installation it turns out that the upgrade has installed successfully anyway. I’ve attached the log file that was created.
Thanks Kyle. I tried all your suggested fixes and still have the problem. Not that it’s that big a deal since the update still installs. I’m just curious as to the cause. Screenshots, log file and sys info attached.
Thanks Kyle. Everything else is working fine. It’s really not an issue because the updates do install. It just keeps throwing up the same error notice. Is there stuff not being deleted I need to be concerned about? If not, I won’t poke the bear!
ok, I’m always of the mind to not fix what’s not broken… obviously something is not running perfectly, but if rhino is doing what you need it to do, I’d stay the course. If it goes off the rails hit us back and we’ll dig deeper.
@dmoyes this is caused by a cached part of a previous installation no longer being present on your computer. We see this most frequently with products that clean up “unnecessary” things on your computer. The most famous is CCleaner (we strongly discourage people from using products like this).
