Rhino 7 wont install after failed update
Rhino 7 wont install after failed update.
Error 2
Error 3
Rhino_7_20210702080632.txt (70.9 KB)
Hi
These problems usually happen when people use something like CCleaner to clean up “unused” files. The problem here is that files that were previously cached on your computer are now deleted. To fix this, please run this Microsoft Fix-It tool, and select Rhino from the list. Once the repair is made, you should be able to install again.
https://support.microsoft.com/en-us/help/17588/windows-fix-problems-that-block-programs-being-installed-or-removed
Any luck?
Hi John,
Thank you very much !!
I started by uninstalling CCleaner, then ran the Fix it tool.
I had to run it a couple of times, it also uninstalled the Rhino Installer engine.
It all seems to be working fine.
Thanks again
Mike.
