Hi all,
Unfortunately I’m not able to reinstall on my laptop the latest version of Rhino 6. After the failed attempt to update it, I still getting error package rhino.msi not found, I uninstalled and deleted the installation folders, but unfortunately nothing done, I get always the same error. I attach some screenshots, I hope you can help me solve the problem, Thanks.
Thanks to Giuseppe Massoni (tech support) I have solved the problem above. It depends on some Windows Updating issue, however here some useful tips:
- Error code 1603: https://wiki.mcneel.com/it/rhino/6/install/error/1603
solved by Microsoft’s Fix
to avoid this screen errors run Microsoft’s Fix and remove this three:
- Rhino6;
- Rhino Engine Installer;
- Rhino Language Pack:
In my case it worked.
