Unroll orientation
What determines the UV orientation of an unrolled surface relative to the World XY plane?
Thanks,
Eric
This can be a combination of two factors:
  1. the UV orientation of original surfaces
  2. direction of the natural vector
Hi Piotr, Experimenting with different combinations of UV and Normal directions, UnrollSrf will mirror or rotate the results 180 degrees, but the unrolled UV orientation seems to be fixed ie: apparently there is no way to change whether U will be oriented along X or Y. In the image, I would like the unrolled intersection curve to be oriented along the X axis.
Eric
my guess:
all developable surfaces are ruled surfaces.
and it looks like the ruling line along one edge (smallest uv-value ?) will be parallel to the x-axis.
… just a guess.
I think it is important, that the UVN directions follow the right hand rule.
This seems to be the case. Thanks.
Eric
