UnrollSrfUV Linear direction
UnrollSrfUV has the (new to me) Linear direction option.
I tried all 3 options (Natural, U, V) and couldn’t find a difference in the result.
The help doesn’t tell me about the 3 options.
What is the purpose?
Noone knows?
And now the option is gone.
Wow, the unexplainable option is back.
Hi Charles,
Good question — this one’s been undocumented since v6, there’s an old thread on it too.
UnrollSrfUV is the Smash algorithm: it flattens by treating one parametric direction as the straight “ruling” direction and developing the strip along it. LinearDirection just forces which direction that is:
  • Natural — Rhino checks U and V and uses whichever is actually straight to tolerance. If both qualify (or it’s a tie) it falls back to U.
  • U / V — skips the check and forces that direction.
So on most surfaces you won’t see a difference: Natural already resolves to U, so Natural and U are identical, and on a genuinely developable patch the U and V flatten come out congruent — same shape, just placed differently. It only actually changes the result when the surface is truly different between U and V, one direction ruled and the other not.
The option showing up and then disappearing is odd — it’s there whether you pre- or post-select the surface, so that’s not what’s triggering it. i’ve logged that along with the missing docs so we get it written up and looked at. RH-97061
@Japhy
your explanation is what i would ve expected …
but:
(mac intel rhino 8)
i can not see any difference for the “linear direction u” “linear direction v”
can you give any example, where we get different results for the options u, v ?
unrollSrfUV_lineardirectionfail.3dm (3.3 MB)
cheers - tom
Followed up on this in the current beta — i built a doubly-curved test surface (so the U and V directions are genuinely different) and ran UnrollSrfUV with LinearDirection set to U, V, and Natural, confirming each one actually took.
All three gave an identical flat pattern — same area, same outline, no difference at all. So in the current build the option isn’t changing the result, which lines up with what you’re seeing.
i’ve noted that on the YouTrack (RH-97061) — it should either do something meaningful, get documented, or be removed.
RH-97061 is fixed in Rhino BETA
