[python] change Rhino.Geometry.Unroller result orientation?
Are there any means to influence how the result is oriented (mainly if it is Z+ or Z-).
Telling the method/rhino what should be up and what down.
I don’t see a method or a property here:
https://developer.rhino3d.com/api/RhinoCommon/html/T_Rhino_Geometry_Unroller.htm
Hi @ivelin.peychev , did you ever find a solution?
Even UV directions are not coherent after unroll.
