How can I make sure that the texture follows surface UV direction and at the same time uses a uniform size?
The planar mapping can fix the size problem but does not follow the UV direction.
The surface mapping follows the UV direction but does not have a uniform size.
Can someone solve this problem without applying using the surface mapping to each surface
